Quadri
Quadri 2022.6 Release Notes
09-01-2022 23:56
Release date: 02.09.2022
QUADRI FOR WINDOWS
General
NEW: Automation tool for an efficient way to produce missing data in the model according to the project requirements.
See full function description here.
FIXED: Explorer search not allways working properly.
FIXED: General bug fixes and enhancements.
FIXED: Incorrect rotation in TTM import.
FIXED: Crash when importing and previewing GUDB data.
FIXED: General bug fixes in IFC import.
Connectors
FIXED: Tekla Structures connector: Some geometries, including rebars, were not always transferred correctly. You must use the Quadri Connector ver. 1.8.15 to make these fixes work.
Conversion Rule Editor
ENHANCEMENT: The Conversion Rule Editor is now a floating dialog, and the user doesn't need to exit it every time he/she wants to click a feature in the graphic windows in order to see the properties in the properties pane.
ENHANCEMENT: Tooltips when mouse hovering over the functions in ribbon.
ENHANCEMENT: Ignore source value if no mapped value. When mapping values and no mapping is set, the full original value was written as a value to the attribute. Now it will leave this empty.
Presentations
ENHANCEMENT: Clean up of WMS templates. Removed Norge i Bilder, NVE Flomsoner, NVE Skred og kvikkleire. Updated with new URLs for the others (NOR config).
ENHANCEMENT: Added possibility to run Table View to Excel in batch (task performer).
FIXED: Crash in Table presentation milestone.
Export
NEW: LandXML: New option to join multiple surfaces in task settings, if they have neighbouring triangles. See more here.
NEW: LandXML: Added Conversionfile for CombinedSurface function.
FIXED: When starting Publish DGN, the ribbon comes up twice.
FIXED: Export to NADAG crash
10-13-2022 08:43
The best one is the Tekla Structures connector and it really helps them in the system. ultimate meaning of white rose symbol
The Conversion Rule Editor is now a floating dialog, and the user doesn't need to exit it every time.
