QUADRI FOR WINDOWS
General
ENHANCEMENT: Inconsistency with Recent Used Task Queries. Some tasks where not listed. Also fixed dialog compression.
FIXED: When changing a conversion file with an updated in the Project Rules, it does not update when the filename is identical.
FIXED: Check mark in Dynamic Query is back, showing that tasks or features have been selected
Insert
NEW: Added support for importing DXF-format in Import (and Present As)
ENHANCEMENT: Problems with inserting WMS when wrong protocol version used. Added option to select protocol version
Conversion Rule Editor
ENHANCEMENT: Regular Expression support for for sub attributes, to use when having multiple attributes with similar names.
FIXED: General bugfixes in Conversion Rule Editor
Modelling
ENHANCEMENT: Move vertically support lowest/highest surface priority
ENHANCEMENT: Overlapping outer boundaries is not supported in Ground Surface
ENHANCEMENT: General enhancements in Ground Surface tool
FIXED: Move vertically destroys line when calculation basis is two or more surfaces
Presentations
ENHANCEMENT: Improve performance in SpreadSheet in Table View presentation
FIXED: General bugfixes in Table View presentation
FIXED: Renderhandler for text shows too many decimals when presenting in the windows. Now shows exactly as defined in the value of the property
FIXED: Crash when zoomed far out when using Dynamic Section
FIXED: Objects with built-in textures, like road signs, only displayed in one 3D-window at the time, and disappear when multiple window activation
FIXED: When viewing a Slope surface task with no data on it, together with a task that has geometry, you still don't see any data.
Output
ENHANCEMENT: Added Render handler RailRoad, to show sleepers in TrimBIM (Trimble Connect and Quadri for Browser), 3D tiles, 3DPDF, etc
ENHANCEMENT: See-through textures like fences now looks correct when publish to TrimBIM
FIXED: When publishing TrimBIM to Trimble Connect, you get multiple “Error layer name not found”, and random layerstructure
FIXED: After publish to TrimBIM, not all layers can be shown/hidden
FIXED: Road Marking objects with holes are not correctly published to TrimBIM
FIXED: Grid terrain with draped ortophoto not working when publish to TrimBIM
FIXED: When publishing TrimBIM, the 3D presentation is sometimes blue
FIXED: General bugfixes with publish to TrimBIM
FIXED: When exporting to QuadriModel and doing a selection of features, all tasks are exported even though not selceted
FIXED: General bugfixes with IFC export
Quadri Connector for SketchUp
FIXED: SketchUp Connector crashes when using SketchUp desktop, while SketchUp is not installed
Quadri Connector for Quest
ENHANCEMENT: General Quest connector enhancements
