Quadri
Quadri 2023 Release Notes
12-22-2022 05:07
Release date: 22.12.2022
QUADRI FOR WINDOWS
International Version
General
Quadri for Windows & Novapoint works with Windows 11
ENHANCEMENT: Dynamic Query now remembers the expand/collapse from last time.
FIXED: Crash when workset have more then one custom feature catalog.
Import
FIXED: Can't save binder when Trimbim as referance data is in the binder.
FIXED: When the model has units in ft, some WMS services display meter values.
FIXED: Support WMS & WMTS from the USGS National Map.
FIXED: Bug with validation errors and none result objects in Quadri G4 import.
FIXED: Re-import GML crash when Imported from Connect.
FIXED: General bug fixes in DWG import.
FIXED: General bug fixes in GML import.
Modelling
NEW: Automation Tool: Added new option to ignore mother feature type.
ENHANCEMENT: Automation Tool: Better logic with “loose” connection lines that are not connected to a minimum of 2 boxes.
FIXED: General bug fixes and improvments in Automation Tool.
Presentations
NEW: Update of DevExpress framework for the nodes tree in Presentation Rule Editor and Presentation Setup. Will give a cleaner look.
FIXED: Crash in “Find the presentation rules..” in Presentation Setup.
Output
NEW: Added option to “Don't swap Y, Z” in settings when publishing to FBX. As default this is off.
FIXED: General bug fixes and improvments in TrimBIM publish.
NEW: Enable changing folder when Publish to Trimble Connect
Quadri Connectors
NEW: Quadri Connector for AgileAssets (beta). Download asset data from an AgileAssets database into a Quadri model. Send asset information for features (points and lines) to the AgileAssets database.
