Quadri
Quadri 2023.1 Release Notes
03-09-2023 06:52
QUADRI 2023.1
Release date: 09.03.2023
Click here for information about Known issues and Compatibility Breaks.
QUADRI FOR WINDOWS
General
Quadri for Windows & Novapoint works with Windows 11
ENHANCEMENT: When using Measure tool, and then use Caption tool for screenshot, the measure will also be saved in screenshot/capture.
FIXED: DynamicQuery: collapse don't work when search field has been used
FIXED: Task tree in Explorer does not update correctly in some cases, looks like tasks are missing.
Import
NEW: Support for import and export of IFC 4.3. New conversion rules for import and export of terrain, alignments, road and water & sewer models are included. A new tab in the IFC export settings dialog allows you to define the spatial breakdown structure and functional systems in the exported IFC-file. Learn more here - IFC 4.3 File Import/Export
NEW: IFC import/export - support multiPoint
ENHANCEMENT: Export to LandXML, wizards for stakeout to also include Railway tasks
ENHANCEMENT: Increase timeout limit so that slow WMS servers work
ENHANCEMENT: TrimBIM insert to support TexturedBillboard
FIXED: When importing a file, the process of reading file to temp model is repeated after conversion rule is selected.
FIXED: Task template for WMS “Geonorge Kommunedelplan” (NOR only)
FIXED: General crashes in WMS
FIXED: IFC import wrong when imported IFC file with length unit is mm
FIXED: Import finishes, even if Cancel import har been clicked
FIXED: Reimported LandXML alignments crash when new worksets are downloaded
FIXED: Reimported LandXML alignments crash when changes are received
Conversion Rule Editor
FIXED: Crash in Concatenate using other characters than letters and numbers
FIXED: Source line not deleted after save of the conversion rule.
FIXED: Not possible to change dropdown:
Modelling
NEW:
FIXED: Building tool generates wrong geometry if generated twice: “feature has multiple attributes with the same type ID. Bygning[-XXXX]”
FIXED: When implementing auto generate sweep, the possibillity to select different attributes for Height/Diameter Outer or Inner was lost. This is now fixed.
FIXED: General bug fixes in Automation tool
Presentations
NEW:
FIXED: SectionSurfaceWidthAndSlopeInfo RenderHandler was not working in version 2023.
FIXED: AlignmentPointInfo are not drawn in 3D view
FIXED: General bug fixes in Presentation Setups tree view, like checking/unchecking nodes, showing correct number of objects in counter.
FIXED: Paste option is missing from Presentation Rule Editor
FIXED: Set ValidAsResult checkbox value in Drawing rule editor not saved
Output
NEW: Publish to CAD preview. When previewing during publish, you can show the real DWG.
FIXED: TrimBIM publish - Not all classifications are exported
FIXED: TrimBIM publish - PipeArrow text too big
