View Entry
Quadri
Civil Construction & Infrastructure Solutions
Back to Library
Quadri ORD Connector v1.4 Release Notes
Recommend
11-01-2022 12:20
David Kosakowski
November 2022
New & Improved
This Quadri OpenRoads Designer Connector release includes these new features and enhancements:
“Select Objects” is now “Pick Objects”
Updated Terminology
- To avoid confusion with the “Select Objects” task in Bentley OpenRoads Designer (ORD), the functionality and button for picking which objects to send from ORD to Quadri via the Connector has been renamed to “Pick Objects”.
Improved Object Selection
- When selecting a parent node in the “Pick Objects” window, all child nodes will now be automatically selected too.
“Always on top” Toggle
- You can now manually determine whether you would like the “Pick Objects” dialogue box to remain “always on top” via a manual checkbox.
Graphically “Pick Objects''
- You can now manually pick objects within the OpenRoads UI, using their cursor, before or after opening the “Pick Objects'' dialog. Once the desired objects are highlighted, clicking the “Synchronize to Selection” button will update the explorer to reflect these selections.
Improved Usability
Improved Navigation During Send
- While sending data to Quadri, the OpenRoads Designer screen will no longer be “locked” if the Conversion Rules window is launched within Quadri.
Deleted Tasks
- If you attempt to select a task that has been deleted in Quadri, a warning message will now appear to inform you that the task no longer exists.
Improved Performance
Improved performance while sending BREP and Parametric cells to Quadri reduces loading time.
Improved performance of gathering MicroStation geometries
Improved Quadri Data Transfer
Better data transfer functions
- These are now supported:
Meshing of unsupported solids (extended elements, BREP cells with holes, etc)
Creation of bounded solids instead of TIN surfaces when meshing Bentley MicroStation solids
Import of utility/drainage links as meshes from OpenRoads to QuadriSupport meshing of unsupported solids (extended elements, BREP cells with holes, etc).
Exporting additional elements from OpenRoads to Quadri including:
Grouped Holes
Text Elements
Complex String Elements
Full Circles
Extended Element Solids
Cone Elements
Extrusion Solids
Arc Elements
Complex Shapes
Parametric Cells
Terrain Elements
Trimble 2022 All rights reserved. Duplication is strictly prohibited. All trademarks registered.
1 Files
5 Downloads
Attachment(s)
Quadri ORD Connector v1.4 Release Notes.pdf
355 KB
1 version
Uploaded - 11-01-2022
Download
Download Document
Please accept the terms of the copyright associated with this attachment before downloading it. Click the link below to read the terms.
Accept
