View Entry
Quantm
Civil Construction & Infrastructure Solutions
Back to Library
Quantm 2023.2 Release Notes
Recommend
03-02-2023 07:37
David Kosakowski
For the full notes with images, see the PDF linked below.
New and improved features
New Help system
A new Quantm help page can be found
here
. Or navigate directly from Quantm.
Contours (height curves) saved in the scenario
250 km version able to choose manual or local optimization
Users with the 250 km version of Quantm can now choose to run optimizations as before on the server or use the local machine. The server will of course be a lot faster than using the local CPU’s for long optimizations.
Add a cost unit for CO2
Crossing rule for structures
It is possible to cross a zone or a feature with a structure over or under. You can apply two different crossing types depending if you cross over or under.
Possible to turn off structures
In preference setting you can turn off structures; bridges, tunnels and retaining walls.
Fixed
Scaling issue for Crossing rule for features/zones
The scaling of the bridge type windows has correct scaling and it’s possible to view the entire name of the bridge type
Crossing Clearances Rules for Culvert
It’s now possible to apply a culver crossing clearance.
Import reference alignment
Is now working with the new version 2023.2 and you can now import or receive alignments with the existing cross section, tunnels and bridges.
Change name: Catalog > Template
For terminologic reasons, the former name “catalog” is change name to “template”
1 Files
18 Downloads
Attachment(s)
Quantm 2023.2 Release Notes.pdf
1.73 MB
1 version
Uploaded - 03-02-2023
Download
Download Document
Please accept the terms of the copyright associated with this attachment before downloading it. Click the link below to read the terms.
Accept
