Release Notes | 03-23-2022 | Connect 3D Viewer 1.4.8
03-23-2022 08:19
There is a new version of the Trimble Connect for Browser 3D Viewer available at  https://3d.connect.trimble.com. Version identifier for this release is: 1.4.8
Note the recently updated device requirements
The change that was announced in the banner message and in the Connect Product Updates forum in early January has been deployed. In short, Trimble Connect 3D viewer requires iOS version 15 or higher on Apple iOS devices. More information is available in the blog post.
This version update has new features:
Reorder properties in the property set library. Now it is possible to change the order of the properties in a property set using the Property Set Manager. Simply drag & drop the properties to the desired order.
After editing the properties click Publish to make the change visible in the 3D viewer properties panel (remember to click Refresh if prompted).
This version update contains improvements and fixes:
  • Fixed an issue where deleting object links in the Attachments tab failed
  • Fixed an issue where an IFC model exported from a certain application failed to load
#Release_Notes
#Trimble_Connect_3D_Viewer
