Release Notes | 04-21-2023 | Connect 3D Viewer 5.1.0
04-21-2023 08:10
There is a new version of the Trimble Connect for Browser 3D Viewer available at web.connect.trimble.com. Version identifier for this release 5.1.0.
This version update has improvements:
  • Rule Based Organizer: Now all drop-down options of a property are listed in the Organizer panel when a drop-down property is used for grouping in the rule:
  • Now the application informs user if they are attaching / linking information into a model object that cannot be guaranteed to have a persistent globally unique identifier:
  • Now it’s possible to change the order of the Property Sets in the Property Set Manager page by dragging and dropping
  • Now the data table remembers the previously active column configuration preset between sessions (on the specific browser)
  • The data table column configuration (Add or remove properties) dialog’s name field has been improved: Now 1) first give the new preset name and 2) then click the Save / Save as button to create a new data table preset:
  • There are new options in the data table’s Save to Organizer feature:
    • Now there are 3 options:
      • 1) As a new group (the same as earlier behavior)
      • 2) As a subgroup (save as a subgroup of the group that is selected in the Organizer panel
      • 3) Replace selected group (replace the group that is selected in the Organizer panel)
This version update has fixes:
  • Fixed a UI layout problem in smaller device screen sizes where the Back button was misplaced
  • Fixed an issue where the “Enter VR Mode” button did not appear correctly when viewing with a VR headset
  • Fixed an issue with data table: After applying color filter and selecting a specific row, the filter was not reset when 'All Objects' mode was selected
  • Fixed an issue where the Publish button of the Property Set Manager was not visible after scrolling the page
  • Now it’s not possible to create a new Organizer group with the same name as an already existing group (duplicate name) anymore. This prevents an issue occurring where two groups with the same name get mixed together.
#Release_Notes
#Trimble_Connect
#Trimble_Connect_3D_Viewer
