Release Notes | 08-05-2021 | Connect 3D Viewer 1.2.6
08-06-2021 05:36
There is a new version of the Trimble Connect for Browser 3D Viewer available at  https://3d.connect.trimble.com. Version identifier for this release is: 1.2.6
This version update contains new features:
The clip plane tool now highlights cut surfaces with a hash pattern:
The properties panel now shows the “Product” property set (with the same information as the same property set familiar from the Connect for Windows application):
This version update contains improvements and fixes:
  • Added a new "Delete all markups" option to the toolbar’s “Markup options” dropdown
  • Added a new "Delete all measurements" option to the toolbar’s “Measurement options” dropdown
  • Added a new "Delete all clip planes" option to the toolbar’s “Clip plane options” dropdown
  • Fixed an issue where the weight units did not not adjust correctly from metric to imperial in the properties panel
  • Fixed an issue where the text markup was not created properly for a specific scenario
  • Fixed an issue where custom extensions could not be added in settings using the advanced extension configuration
  • Workspace API:
    • Added new DataTable API
    • Added new Markup API
    • Added new ModelsPanel API
    • Breaking change: Moved existing measurement markup APIs to Markup API
    • Added new data structures MarkupPick, Markup, LineMarkup, ArrowMarkup, MeasurementMarkup and CloudMarkup
    • Added add and get APIs for ArrowMarkups, LineMarkups, TextMarkups and CloudMarkups. Added new removeMarkups API
    • Breaking change: Change the parameters type of "getObjectProperties" API from Viewer API, to accept an array with all the objects, instead of a list of arguments for each object
    • Technically enabled embedding viewer to tightly sandboxed environments
#Release_Notes
#Trimble_Connect_3D_Viewer
