Release Notes | 03-09-2021 | Connect 3D Viewer 1.0.174
03-09-2021 11:43
There is a new version of the Trimble Connect for Browser 3D Viewer available at  https://3d.connect.trimble.com. Version identifier for this release is: 1.0.174.
Highlight from an earlier release:
Organizer Access Control: Learn more about the new organizer access control feature here.
This version update contains new features:
Rotate clip plane: After adding a clip plane, it’s now possible to rotate it to the desired angle
Status sharing extension (BETA): The status sharing feature is now available as an extension. Project Admin can enable the extension for the project (Business Premium, Enterprise or Project license is required to enable the extension)
Organizer sorting: The Organizer panel has new sorting options:
Organizer filtering: The Organizer panel has new filtering options:
Organizer edit mode: The Organizer panel has a new edit mode: Click the pencil icon to edit the name of the organizer group:
Data table new export option: The data table has new options for exporting as CSV: The “Export to CSV (current groupings)” is a new option which exports only the currently visible top level groups. The “Export to CSV (no groupings)” exports all rows in the table.
This version update contains improvements and fixes:
  • Sort alphabetically option in the properties panel now sorts also the properties inside the property sets (previous it sorted only the property sets)
  • Improved object coloring related to assembly vs object selection. The new behavior is the following:
    • if individual object from assembly is selected and colored, the object will always change its color
    • if assembly is selected and colored, the objects from the assembly will change their color only if the individual objects aren't already colored. So in this case if the assembly has objects A and B, and none of the objects are colored, both A and B will have the color selected for the assembly. If A has no color, but B has a color, only A will have the color selected for the assembly, and B will preserve the color it previously had.
    • This also fixes an issue with the data table colorize feature when colorizing assemblies
  • Fixed an issue where IFC file from Bim2field was not loading in 3D
  • Fixed an issue where the new updated model revision was not showing markups from previous version when loading view
  • Fixed an issue where selection did not work with certain Tekla models
  • Workspace API:
    • Removed deprecated Query API
#Release_Notes
#Trimble_Connect_3D_Viewer
03-11-2021 04:57
Hello Janis,
Thank you, I'm glad to hear your feedback.
Regarding your question: deleting assigned status is not possible in status sharing. Correcting the situation must be done by assigning new correct status. For more details, please refer to the user guide and tutorial video here: https://docs.workflowextensions.connect.trimble.com/status-sharing/what-is-status-sharing
03-10-2021 07:43
Hello!
Great update, especially data table and organizer features.
I have one question regarding status sharing. How I can delete assigned status, if I assigned wrong status or wrong date?
