Release Notes | 10-25-2021 | Connect 3D Viewer 1.2.22
10-25-2021 08:59
There is a new version of the Trimble Connect for Browser 3D Viewer available at  https://3d.connect.trimble.com. Version identifier for this release is: 1.2.22
This version update contains new features:
DWG XREFs:  Now, when loading a DWG model that references other DWGs all the referenced models are loaded at the same time:
  • Note 1: In order for the DWG XREFs to be detected, the DWG models must have been uploaded to the Trimble Connect project after June 17, 2021. If the models have been uploaded prior to this date they must be re-uploaded.
  • Note 2: The DWG XREFs feature finds the referenced models based on the relative paths. The DWG model paths must match the Trimble Connect project folder structure.
Switch to the selected models panel to see the reference hierarchy and possible broken XREF file paths:
This version update contains improvements and fixes:
  • Improved the data table loading and CSV export performance. Also now progress animation is displayed during the CSV export
#Release_Notes
#Trimble_Connect_3D_Viewer
