Release Notes | 12-12-2022 | Connect 3D Viewer 4.0.0
12-12-2022 09:09
There is a new version of the Trimble Connect for Browser 3D Viewer available at web.connect.trimble.com. Version identifier for this release 4.0.0.
Important information for all Workspace API integrations:
If you are consuming the Workspace API to create extensions, or for embedding the Connect 3D viewer, please see important actions you must take before the end of Q1 / 2023:
see post in the Connect API Integrators forum.
This version update contains new features:
New center snapping option: The measurement tools now have a new center snapping option. To try it, first active one of the measurement tools in the toolbar:
Then use the new center snapping option:
The center snapping option detects the following scenarios:
Snap to center of a pipe:
Snap to center of rebar:
Snap to center of a bolt:
Snap to center of I beam:
This version update contains improvements:
  • The workflow to update a view in the view details panel has slightly changed. Now, the user must first click on the edit icon, then update view and save changes:
    • The purpose of the change to reduce the number of unintended updates of the view
  • The Rule Based Organizer now Indicates that a rule based group is outdated immediately when there is a new model version uploaded (not having to reload the Organizer panel)
  • Now, there is a confirmation question presented when creating a new rule based group and saving the rule would result into a very high number of groups:
  • Now, the Organizer panel presents a confirmation question before proceeding to load a group with very high number of subgroups:
  • The Organizer panel now delays loading group contents until expanded. This improves the initial loading speed of the Organizer panel
This version update contains fixes:
  • Fixed an issue where attaching a file to model objects of certain model file formats failed
  • Fixed an issue where loading attachments of certain models failed (opening the attachments panel failed)
  • Fixed an issue where clicking “Reset model” also reset the user’s DWG viewing preferences in Settings → Preferences. Now the user’s DWG model viewing preferences are retained
  • Fixed an issue where the single point measurement tool was not available on tablet computers and mobile phones
  • Fixed an issue with inverted camera presets in the toolbar (front / back & left / right were opposite of the intended)
#Release_Notes
#Trimble_Connect_3D_Viewer
12-13-2022 04:01
Snap to center works great, can this also be developed for TC-Desktop?
