GeoSuite
Release Notes Geosuite 2020.0.1
05-03-2023 01:51
Version 2020.0.1
Release date: 2020-12-22
Updates for Novapoint GeoSuite Toolbox/Archive
License handling
Changed default time for time-wait for license check - affects calculation modules
GeoSuite Calculation license and Flex LM, a user can simultaneously use all calculation modules
Updates for Novapoint GeoSuite Presentation
Support for Novapoint 2020(ac 21) with AutoCAD 2021
Borehole can be drawn with specified A1/A2 frame
Draw PDF - new option to specify paper format
New Borehole draw-option, draw methods side by side
Fix: Colors for soil interpretation should be same colors as in AutoCAD
Fix: When Geosuite makes a zip-file for a project all files dates are a month later.
Norwegian version
Do not longer set background color to grey if “AutoGRAF”-color (Norway)
Command missing i Norwegian AutoCAD-menu: Switch Interpretation text on drawing Soil layer/Soil description
Swedish version
Bug fix: Soil nomenclature is not correct in Swedish for peat
Fixed some English resources in libraries
Groundwater export from selected boreholes.
Option in Settings if we have to follow SGF-standard or not for Swedish soil test
Updates for Novapoint GeoSuite Stability
Bug fix for use of existing line from XREF with different height/length scales
Bug fix for command BeastRun, updated for calculations in Temp-folder.
Updates for Novapoint GeoSuite Pilegroup
Bug fix for Pacer soil model calculations
Bug fix for conversion of older pilegroup calculations where NTNU was used as soil model
Updates for Novapoint GeoSuite Soil Data Interpretation
Improvements for the map view
Updates for Novapoint GeoSuite Bearing Capacity
Please note that Bearing capacity is still a beta edition
Bug fix for application startup
Updates for AutoGRAF Utvärderingsmodul
Startup-fixes for AutoCAD 2019-2021
