GeoSuite
Release Notes Geosuite 2020.0.11
04-16-2024 03:23
Version 2020.0.11
Release date: 2024-04-19
Updates for Novapoint Geosuite Toolbox/Archive
Support Trimble Drawing 2024.
Bugfix: Client name truncated to 20 characters in restore, export to Cloud and export dbsx.
Bugfix: Minor bug fixes and enhancements.
Updates for Novapoint Geosuite Presentation
Provide warning messages when drawing alignment in profile. Regards function "Ny väglinje" or "Rita väglinje" in GS Sektion/Profil in AutoCAD and the profile alignment include arcs. We recommend reading in road line profiles from NP/Civil 3D.
Rotating plan view with inclined boreholes is displayed wrong in the Norwegian version.
Error handling duplicate GUID:s for NADAG and updating plan view.
Using multiple length profiles from Novapoint. Being able to update a dwg drawing with different alignments, similar workflow with Civil 3D.
Borehole date fix in stamp for the Swedish version, so that the borehole date is included in the stamp.
Update 3rdParty expat to version 2.6.0 .
Bugfix: Draw ground water measurement diagram.
Bugfix: Misleading error text in dbs-export of stop code 96.
Updates for Novapoint Geosuite Piles
Database corrected. In version 2020.0.08b the pile database was corrected because the EI and EA values for 'Steel core' piles were not correct in the 'Geosuite' database. The 'xx/xxx Core' cross-section had values for an 'xx/xxx Core and pile' cross-section and vice versa. In version 2020.0.9 and 2020.0.10 this corrected database was not included. In version 2020.0.11 the corrected database is included. BUT a saved calculation will not be updated automatically. You have to update this manually and the easiest way to do this is by using the 'Use from database' function and selecting the same cross-section again.
Bugfix: Pacer's GWL isn't always at a layer border. Pacer's GWL isn't always at a layer border which it must in order for Pacer to calculate. This is fixed.
Bugfix: Amount of decimals written to pilgen.inp. Only three decimals are written for diameter and wall thickness to pilgen.inp even though it’s possible to use four decimals in the UI. This is fixed.
Bugfix: Upile calculation for steel core database piles.
  • Post processing of Sigma_max and Upile. When using steel core piles from the database, and only core (not core and pipe) a post processing calculation of sigma_max and Upile has been added. The post processing calculation will use the diameter for the core only when sigma_max is calculated. Upile will be calculated using the calculated sigma_max.
  • Post processing of Sigma_yield and Upile. When using concrete piles or steel pipe piles from the database a post processing logic has been added. The logic sets sigma_yield and Upile to N/A for these pile types.
Bugfix: Minor UI bug fixes and enhancements. E-modulus column placed wrong making the column order not logical. Different signs in table and chart for axial stress. Program crash (GetMaxGroundZLevelForUsedProfiles error) in rare cases after added loads and switching to the Piles tab.
