GeoSuite
Release Notes Geosuite 2020.0.13
01-08-2025 05:25
Version 2020.0.13
Release date: 2025-01-27
Updates for Novapoint Geosuite Toolbox/Archive
Support for Novapoint and Quadri 2025
Updates for Novapoint Geosuite Presentation
It is now possible to view the distance between the section line and the borehole, for already generated sections, by typing (IDSEKT 4) in the autocad command prompt
Updates for Novapoint Geosuite Piles
Bugfix:  Aborted calculation when the ground water level was above the pile top
Updates for Novapoint Geosuite Stability
Bugfix: Removed the iteration step from calculation strategy Optimize, as it is no longer supported
Minor enhancement: When using Undo after generating multiple shear surfaces, a message box was displayed with the warning message "You are not allowed to modify...." for each shear surface. Now only one warning message appears.
