GeoSuite
Release Notes Geosuite 2020.0.14
09-16-2025 00:40
Version 2020.0.14
Release date: 2025-09-17
Updates for Novapoint Geosuite Toolbox/Archive
Support for Autocad 2026 & Civil 3d 2026
Support for Trimble Drawing 2025
Updates for Novapoint Geosuite Presentation
Bugfix:  Update plan drawing previously set all rotated symbols as modified, it has been adjusted
Bugfix:  There was an issue using Import wizard due to mismatch in dll:s, it has been resolved
For users using servers to place projects, copying a lot of boreholes to a project could cause read/write issues depending on the server reading/writing speed - resulting in a lock file being created for the project (Autograf.dbk lock file). This risk has been reduced with the new release.
Updates for Novapoint Geosuite Piles
Bugfix:  Aborted calculation when the ground water level was above the pile top
Updates for Novapoint Geosuite PileGroup
Bugfix: Using elevations greater than 100 could result in errors and calculations not being able to go through. This has been resolved.
Bugfix: Applying pile force above ground surface level could result in errors and calculations not being able to go through. This has been resolved.
