Release date: 2022-01-13
Bug fix for Import Archive, .bin-file. Some projects could be included in 2 separate archives.
Support for Novapoint 2022. Please note that Novapoint 2022 also supports Geosuite Databases 4.0, se notes for GeoSuite 2020.0.2.
Bug fix Many profiles and with many vertices and solids from Civil 3D.
Bug fix In AutoCAD for Digitization and Selections sets and Database 3.0. (This bug appeared in 2020.0.2 and some customers has already downloaded updated arx-files)
Bug fix It is now possible again to Graphical Preview Stack Files
Bug fix Plasticity Index not written to the input file if NGI-05 method is used.
Bug fix Calculation of inner diameter/outer thickness for composite cross sections doesn’t work correctly (for example calculated inner diameter is sometimes not in compliance with outer diameter and thickness).
Bug fix The “User defined” head condition doesn’t work (in some cases)
Bug fix Headers in tables are not all black.
Bug fix Complete text is not visible for “Time increment” choices (“Automatic” / “Specify…”).
Bug fix Too few decimals for load coordinates and “a”. This affects load stresses for calculation points on the boundary of two loads beside each other (the generated stresses become a bit too low and even though it normally has no practical importance it should be fixed).
