GeoSuite
Release Notes Geosuite 2020.0.6
05-03-2023 01:41
Version 2020.0.6
Release date: 2022-10-17
Updates for Novapoint GeoSuite Toolbox/Archive
Bugfix: Some transformations not found, for instance SWEREF 99 TM (Fixed now but way around is to transform in GS Presentation-Export)
Check of document sizes in Export to GeoSuite Cloud.
Configuration file, new options for license mix of FlexLM and TrimbleID:
  • NETAVD=LMPRESENTATION if GS Presentation with TrimbleID and otherwise FlexLM.
  • NETAVD=LMCALCULATION if Calculation modules with TrimbleID otherwise FlexLM.
Support for Drawing
Updates for Novapoint GeoSuite Presentation
Bugfix: 2020.0.5 could not update profile drawings for AutoCAD 2019/2020
Updates for Novapoint GeoSuite PileGroup
Bugfix: Pile group center not working correctly (labels changed & default values added preventing pile group center not being set)
Bugfix: Correct old pgjson files without pile center set
Bugfix: Windowing and then maximizing result window not working correctly
Bugfix: Storing calculation file on server causes problems when opening
Bugfix: Group action values not validated
Bugfix: Soil properties not shown correctly in graph
Bugfix: Bad error messages more explanatory
Bugfix: Wrong curve for plastic capacity for steel core piles
Bugfix: Y-axis displacement wrong in plan view
Updates for Novapoint GeoSuite Soil Data Interpretation (SDI)
Bugfix: Calculate’s “Finish” enabled despite calibration factors are missing
Bugfix: Stress history and sensitivity axes scale incorrectly
Bugfix: OCR line in stress history must update when changing method for calculating OCR
Bugfix: Select/unselect option in borehole selection does not display correctly
Bugfix: Opening saved SDI files through GS Arkiv creates a dialog loop
Bugfix: Header for liquid limits trendline is wrong
Bugfix: Short command for help function not working
Bugfix: Statistical analysis for graphs - trend line covering graph
Bugfix: Program crashes when moving/dragging headers
Bugfix: Import wizard (File conversion wizard - InterpretedOedometerData) spelling mistake
Bugfix: Graphical scale issues due to legend
Bugfix: Changing values in oedometer interpretation does not update preconsolidation stress chart
Updates for Novapoint GeoSuite Stability
Bugfix: Too long file name causes error when saving results
Bugfix: Generate Report fails
