GeoSuite
Release Notes Geosuite 2020.0.8a
06-30-2023 04:06
Version 2020.0.8a
Release date: 2023-06-30
Updates for Novapoint Geosuite Pilegroup
Critical bugfix: The EI and EA values for 'Steel core' piles were not correct in the 'Geosuite' database. The 'xx/xxx Core' cross-section had values for an 'xx/xxx Core and pile' cross-section and vice versa. The database is now updated with the correct values BUT a saved calculation will not be updated automatically. You have to update this manually and the easiest way to do this is by using the 'Use from database' function and selecting the same cross-section again.
04-09-2024 03:08
@sebastien resseguier Hello Sebastien, all the bugfixes implemented in previous versions are also valid for the next releases.
If there is any change that will affect a previous implementation, it will be commented in the release notes of the affected version.
In 2020.0.8b it is also fixed.
So the advice is to install 2020.0.8b if you are in a hurry to work with this specifically. Otherwise, wait for 2020.0.11 where the new  database library will be again implemented.
04-09-2024 03:00
Is this bugfix also implemented in version 2020.0.10 / 22.0.10?
