Novapoint Bridge Library
Release Points
04-05-2021 13:46
This function can be used if you want to release one or more points on a bridge cross-section. If you want to delete points/elements of a bridge section you can use this function. This function is the opposite of Lock/Connect Points. You have to select all the points on the cross-section that are to be released.
MOUS_ICO Menu: Bridge Edit Release Points
MOUS_ICO Toolbar: Edit Release Points
Command prompts for:
Select a point:
Select all the points, which are to be connected and locked. Finish with the key Return or the Right button of the mouse.
After the function has been executed, you will be asked if you want to save the new settings to the database. Opt Yes to save the changes. The points that are connected will be colored with red grips and those, which are free, will be colored with cyan grips.
