Novapoint Noise Library
Reset Text
04-15-2021 14:46
MOUS_ICO Menu: Noise > Calculation points > Reset text
or
nco: Select a calculation point
MOUS_ICO Popup menu: Reset text…
Texts attached to calculation points, color scale, etc. are replaced according to the coordinate set-up (UCS) of a drawing. If one changes the viewport e.g. by rotating the drawing, one may define a new coordinate set-up for this viewport, and after that select Reset text for all calculation points in the viewport. These texts will then be replaced according to the new coordinate setup.
By running Reset text with different selections of active calculation points and different coordinate set-ups, one may in one and the same drawing have the texts at calculation points rotated differently. They will still be updated at the same place by new calculations, new selections of what to be in the texts, etc.
By changing Placement for Object type Calculated calculation points or Uncalculated calculation points in the dialog box Style, a question of whether to reset the texts or not will appear.
