Quadri
Restore Model from Backup
03-28-2021 20:07
MOUS_ICO Models > Select Model > More > Restore
Note that the model needs to be unavailable before you can restore it from backup.
Select a timestamp from the drop-down list Select Time to Restore.
When selecting a timestamp, a list of worksets that will be lost after the restore will appear. All worksets created after the timestamp will be lost.
If the backup you want to restore from is located on tape, you need to copy the backup files to a directory on the disk first. Type the path of the directory in the text box Path to Restore from.
Click the Restore Model button to start the restore.
Restoring a model from backup will take some time. A message will appear when the process has started. The Maintenance column in the Models list will show Restoring while the restore process is running. When the process is finished, the Maintenance column will be blank.
