Novapoint Road Library
Road Access
04-19-2021 14:55
This function designs road access along any selected reference line.
  • The resulted road access will be a 2D drawing
  • Elevations to the 2D Road Access drawing can be defined using the Elevation Tools
  • The function does not modify the road model or the database (Quadri Model)
MOUS_ICO Toolbar: Not available from the Toolbar
MOUS_ICO Menu: Road > Intersection Tools > Road Access…
Command prompt for:
Pick a line, arc, polyline:
Pick left or right side:
Preview of the road access will be drawn in AutoCAD with the default parameters.
  • The preview is updated automatically when parameters are modified.
  • The unit of linear measurement and angular measurement are metres and decimal degrees, respectively.
Hook <
Defines the location of the access road on the selected reference line.
  • The preview will glide along the reference line.
  • Pick the point for the start of the road access, use snap modes for precise pointing.
  • Alternatively, type in the start chainage in the dialog.
End <
This function defines the end point of the access road.
  • The end point of the access road moves with the cursor movement.
  • Pick the end point of the road access.
  • Use snap modes for precise pointing.
Move <
Use this button to move the entire road access.
  • Pick the new start point
Parameters
  • Station on reference line: Define the station number for the start of the road access
  • Offset from reference line: Define the offset from the reference line
  • The radius of approach edge line: Define the radius of the approach edge line. The parameter is related to the command 'lanesetup' (left lane driving/right lane driving).
  • The radius of exit edge line: Define the radius of the exit edge line. The parameter is related to the command 'lanesetup' (left lane driving/right lane driving).
  • Total width at construction: Define the total road width (left lanes and right lanes) at the access point.
  • Total width at end of road access: Define the total road width (left lane and right lanes) at the end of road access.
  • Distance from access point to end point: Define the distance (measured along the reference line) of the road access end point.
  • The perpendicular distance from end point to reference line: Define the perpendicular distance of the road access end point from the exit edge line.
  • Centreline on/off: Mark the check box if the centerline of road access is to be drawn.
Example Road Access
R1 Radius of the approach edge line
R2 Radius of the exit edge line
A1 Distance from access point to end point
A2 Perpendiculant distance from end point to the reference line
B1 Total width at the constriction
B2 Total width at end of road access
Off Offset from the reference line
