Novapoint Road Library
Road Edge: 2R
04-19-2021 15:01
Use this function to design road edge curves with two arcs.
  • This program can be used in many contexts and for everything that resembles an intersection edge line.
  • The program can construct a tangential connection of two arcs between any two line/arc elements.
  • In addition, straight lines (tangent lines) can also be inserted before and after the arcs.
  • The only requirement is that the angle between the lines is less than 200 grads.
  • The resulted Road Edge 2R will be 2D drawings.
MOUS_ICO Toolbar: Not available from the Toolbar
MOUS_ICO Menu: Road > Intersection Tools > Road Edge 2R
Command prompts for:
Zoom/Pan/Snap/Make/Edit/tanGpnt/Initiate/Drag/unlOck/reFpt/draW/Quit/Vehicle/<Make>:
Make
Use this option to select the two intersecting road edges for designing a road edge line.
Pick start edge line (turning right): Select the edge line for the right turn
Pick end edge line (turning right): Select the other road edge
A preview of the edge line is shown with the default values.
  • The preview will be updated automatically when values are modified.
Vehicle
Use this option to select the design vehicle.
Select Vehicle Group: 0=BICYCLE, 1=CAR, 2=LORRY/BUS, 3=LORRY+T <1>:
Type in a value to select the design vehicle.
Drag
Use this option to change the radius of the arc element or radius of both the arc elements dynamically. The radius on the road edge is changed with the movement of the mouse.
Without iteration/<with Iteration&gt;:
Enter the desired option to continue.
Drag: 1=Radius1, 2=Radius2, 3=Both, 4=Return <2>:
Enter 1 if the starting arc radius and its tangent point are to be changed. Enter 2 if the end arc radius and its tangent point are to be changed. Enter 3 if both arc's radii and their tangent points are to be changed. Enter 4 in no change is desired.
tanGpnt
Use this option to define the straight stretch at both ends of the road edge.
Command prompts for: Pick the end of the edge line: Pick the desired end point of the road edge line. The selected point will be end point of the straight stretch.
End by pointing: Pick the end point of the straight stretch. Novapoint constructs the tangent line. Repeat the same procedure for the other end of the road edge if needed.
reFpt
Use this option to define the reference point.
Select a reference point: Pick the reference point from the drawing. Use 'Object snap modes' for precise selection.
unlOck
Activate the option to calculate the radius from the tangent angle.
Edit
Use this option to edit existing 'Road Edge 2R' construction.
Pick an edge line to edit: Select the road edge to be edited.
Only the road edge lines constructed with the function Road Edge 2R; can be edited with the option 'Edit'.
Radius
Use the option '*1:' to define the radius of the arc elements.
Type radius R1 <17.85>: Enter a radius in meters.
Select the other radius and define the other radius.
Distance
Use the option '*c:' to define the perpendicular distance from the center of the larger radius to the end road edge.
Distance <15.76>: Define the distance in meters.
Angles
Use the option '*b:' to define the included angle for the arc with a higher radius value.
Type angle - beta (gon) <40.00>: Enter the desired angle in grads
draW
The road edge line is drawn in the current AutoCAD drawing.
Example Road Edge: 2R
