Novapoint Road Library
Road Edge: 2R2A
04-19-2021 15:02
Use this function to design road edge curves and draw them to the current drawing.
  • The road edge is designed with two arcs and two transition curve elements.
  • This program can be used in many contexts and for everything that resembles an intersection edge line (not necessarily in association with a road edge).
  • The resulted Road Edge 2R2A will be a 2D drawing.
  • Run the function from the following location:
MOUS_ICO Toolbar: Not available from the Toolbar
MOUS_ICO Menu: Road > Intersection Tools > Road Edge: 2R2A
Command prompts for:
Pick start edge line (turning right): Select the start edge line for a right turn
Pick end edge line (turning right): Select the other road edge
A preview of the edge is be drawn in AutoCAD with default values.
  • The preview is updated automatically when the values are changed
Zoom/Pan/Snap/error ?/draW/Quit/<draW>:
  • All options with an asterisk mark can be define/edited
a
This refers to the intersection angle (in grad) of selected edge lines.
error ?
Use this option to track the errors of the road edge-rounding object. The details will be displayed in Notepad.
draW
The road edge line is drawn to the current AutoCAD drawing.
Example Road Edge: 2R2A
