Novapoint Road Library
Road Edge: 2R3A
04-19-2021 15:03
Use this function to design road edge curves and draw it to the current drawing.
  • The road edge is designed with two arcs and three transition curve elements
  • This program can be used in many contexts and for everything that resembles an intersection edge line (not necessarily in association with a road edge)
  • The resulted Road Edge 2R2A will be a 2D drawing
MOUS_ICO Toolbar: Not available from the Toolbar
MOUS_ICO Menu: Road > Intersection Tools > Road Edge: 2R3A
Command prompts for:
Pick start edge line (turning right): Select the start edge line for a right turn
Pick end edge line (turning right): Select the other road edge
A preview of the edge line is drawn on AutoCAD with the default values.
  • The preview is updated automatically when the values are modified
Zoom/Pan/Snap/error ?/draW/Quit/<draW>:
  • All options with an asterisk mark can be define/edited
a
This refers to the intersection angle (in grad) of selected edge lines.
error ?
Use this option to track the errors of the road edge-rounding object. The details will be displayed in Notepad.
draW
The road edge line is drawn to the current AutoCAD drawing.
Example Road Edge:2R3A
