Use this function to design road edge curves (road edge curves at intersections, road turns, etc.,) and draw them to the current drawing.
MOUS_ICO Toolbar: Not available from the ToolbarMOUS_ICO Menu: Road > Intersection Tools > Road Edge: 3R2A
Command prompts for:
Pick start edge line (turning right): Select the start edge line for a right turn
Pick end edge line (turning right): Select the other road edge
A preview of the edge line will be drawn on AutoCAD with the default values.
Zoom/Pan/Snap/error ?/draW/Quit/<draW>:
This refers to the intersection angle (in grad) of selected edge lines.
Use this option to track the errors of the road edge-rounding object. The details will be displayed in Notepad.
The road edge line is drawn to the current AutoCAD drawing.
