Novapoint Noise Library
Roads and Railroads
04-15-2021 13:51
MOUS_ICO Menu: Noise > Roads and railroads
or
nco: Select an existing road (defined in Novapoint Noise)
For general information about roads in Novapoint Noise, see section roads_and_railroads.
In the menu, the items above the line are functions for roads in general. For the items under the line, an object selection is required. This can be done before the function is called, or afterward. Anyway, the selection will be filtered so it only changes roads. Objects in the selection that are not roads are not affected.
Examples of use that affect a selection of roads
Example 1:
MOUS_ICO Select a road (defined in Novapoint Noise), so the grip points are marked with blue squares.
MOUS_ICO Menu: Noise > Road and railway > Passive
The selected road is now passive.
Example 2:
MOUS_ICO Menu: Noise > Roads and railroads > Traffic Data…
Select objects: will show on the command line.
KEYB_ICO all, <Enter>, <Enter>
will select all entities in the drawing. The traffic data dialog will now appear showing the first road. When pressing the Ok or Cancel button, the dialog will close, but reappear again for each road entity in the selection.
