Use this tool to rotate point elevations.
MOUS_ICO Menu: Terrain > Elevation label> Rotate point elevationsMOUS_ICO Toolbar: Elevation label: Rotate point elevations
Start the function and the command prompts:
Select one or more point elevations to adjust:
Select point elevations to rotate and move the cursor around to find a suitable rotation angle or type it. Selected point elevations will be given the same rotation.
