Use this function to select the Standard and/or Type of the vehicle, for vehicle turning analysis.
MOUS_ICO Toolbar: Vehicle Track Analyzer: Select VehicleMOUS_ICO Menu: Road > Vehicle Track Analyzer > Select Vehicle…
The dialog 'Vehicle' will pop up.
The pull-down menu lists the road standards. Select the desired road standard.
If you have made your own Vehicle and think it should be part of the installation, then contact support and see if we could not put it on the installation for the rest of your colleagues to use in a future update.
The pull-down menu lists the types of vehicles (pre-defined and user-defined if any). Select the desired vehicle for vehicle turn analysis.
Use this button to copy/duplicate a pre-defined/existing vehicle and then edit the dimensions/values thus creating a user-defined vehicle.
This button is enabled when a user-defined vehicle type is active. Only user-defined vehicles can be edited. The dialog 'Vehicle - Edit' will pop up with the button 'Edit'.
Use this button to define loads on some of the parts of the active vehicle type for vehicle turn analysis.
