Quadri
Server Parameters
03-24-2021 21:02
MOUS_ICO Server > Settings > Server Parameters
The server parameters should not be updated unless you are sure they need to be changed.
On this page, you can see and change the parameters for the whole Quadri server. The parameters set here will be valid for all models unless there is a different value set on a specific model. See here for more info on how to set parameters for a specific model.
