Novapoint Road Library
Settings (for the task)
04-18-2021 17:51
Start the task settings to change global settings for the task.
Spatial Data
In this tab, you can set the phase of the model to Designed or Existing depending on if the road task you are working on is already an existing physical road that you are recreating or a new design.
Generic Attributes
Add generic attributes to all the result objects coming out from the road task build.
Generic attributes can come in the form of:
  • Integer values (a number that cannot be a fraction)
  • Real values (a number that can be a fraction)
  • Text (general text)
  • DateTime (sets the date and time of the build)
  • Bool (checkboxes for True/False)
Remember to set a description connected to the generic attribute to better describe what the generic attribute is used for.
These generic attributes can be queried in the Dynamic Query dialogs or Presentation Setups based on the tags 'PropertyName', 'propertyDescription', or any of the 'valueXXXXX' as seen in the queries. They can also be used in the conversion rules for imports and exports.
TIN Priority
To edit the order of TIN priority different than the task dependency priorities already used for the calculation basis, then check the checkbox to edit the priority list.
Road designers should generally not need to do these TIN priorities when a Quadri models terrain and subsurface surfaces is set up correctly. Use this function with care.
