Show 3D model
08-11-2021 04:05
Show 3D model
What
With this function you can see your trench as a 3D model in a CAD-tool.
Where
How
The following method is used:
  1. Start the function
  2. In dialogue, select relevant trenches to see
  3. Select which parameters to use. This can either be done by changing the default or specify for different tasks
  4. End with Create 3D
