Novapoint Bridge Library
Show Perspective
04-05-2021 14:08
Using this tool, you can quickly generate a perspective view of your bridge/structure and terrain.
Note: You have to draw a 3D surface model of the bridge/structure, which is viewed in perspective view. To draw a 3D surface model, run the tool 'Draw 3D Face Model'.
The function will automatically insert a VIEW in your drawing. You will specify a camera position in relation to the centreline. You can also select the direction of view and the focal length of the camera.
Note: You will be prompted for the Road Model, Database (Digital Terrain Model), and Bridge Project if these are not defined in project settings.
MOUS_ICO Menu: Bridge 3D Show Perspective
MOUS_ICO Toolbar: 3D Show Perspective
Command prompts for:
Start station:[m], end station:[m] Enter the station for the view <m>:
Define the start station from which perspective view is desired.
View backwards or Forwards (B/F) <Forwards>:
Define the view direction.
Enter horizontal distance from the road alignment (in m) <default value>:
Define the horizontal distance of viewpoint from the road alignment. The default value is 2.0m.
Enter vertical distance from the road alignment (in m) <default value>:
Define the vertical distance of the viewpoint from the road alignment. The default value is 1.5m (height of a person's eye when in a passenger car).
Enter the focal length (mm) <default value>:
Sight distance.
The function will then generate the specified perspective view of the bridge/structure and command prompts for:
S(Section no)/I(interval)/N(Next)/P(Previous)/H(Hide)/ESC:
S (Section no.):
You can jump to the desired station to have a perspective view at that station. Use this option and define the desired station number.
N (Next)/P (Previous):
You can traverse along your bridge/structure using the option Next and Previous. The function jumps to the next or previous station for a perspective view. The interval of this traversing will be as that defined with the option I (Interval).
I (Interval):
Define the stepping interval of the stations when you traverse along the bridge/structure.
H (Hide):
Functions as Hide in AutoCAD.
ESC:
You can exit the scroll mode. The AutoCAD cursor will reappear.
