This dialog can only be reached from Buildings when Prompt for each building is selected and OK is pressed.
For any potential building (according to Layer name for fetching buildings) which has less area than the minimum value (given in Area in Buildings), this dialog box pops up. The current potential building line is highlighted in red. In this dialog, we select whether to register the red line as a Novapoint Noise Building or not.
Yes
The line is registered as a building in Novapoint Noise. If there are more buildings left with an area less than the minimum area, the dialog Small buildings returns, otherwise we return to the dialog box Buildings.
No
The line is not registered as a building in Novapoint Noise. If there are more buildings left with an area less than the minimum area, the dialog Small buildings returns, otherwise we return to the dialog box Buildings.
Yes to all
All remaining buildings within the selected area are registered in Novapoint Noise, even if they have less area than the minimum area. The dialog Small buildings returns when the registration is finished.
No to all
None of the remaining buildings with an area less than the minimum area within the selected area are registered. The dialog Small buildings returns when the registration is finished.
Zoom in
The drawing scale is increased with the line in question in the center of the screen.
Zoom out
The drawing scale is decreased with the line in question in the center of the screen.
Cancel
The registration is stopped immediately. Any buildings registered before this still will be registered.
Help
Help for this dialog.
