Novapoint Road Library
Split Long Section from Road Design Task
04-19-2021 12:55
This function enables you to split an existing long section, making it possible to better adjust the vertical geometry to the frame. Use this if the vertical line/geometry has significant differences in elevation along the path, enabling different parts of the long section to have different reference elevations.
Procedure
MOUS_ICO Toolbar: Not available from toolbar
MOUS_ICO Menu: Road > Draw Longitudinal Profile > Split Long section from Road Design Task…
  • Select frame by marking the insertion point of the section.
  • Type in which station you want to split the section.
  • Type in the new datum (elevation) from the selected station.
  • Select Add to store the information in the table (multiple splitting points can be defined).
  • Execute the function by selecting Update.
