Start Configuration
04-12-2021 16:20
Start Configuration
What
This function is used for the following operations:
  • Register the Water and Sewer objects such as !!pipes!!, !!manholes!!, materials, valves, hydrants, connections, etc., that shall be used in the Water and Sewer Project.
  • To define/edit the relation among the registered objects such as the following:
    • Among various materials available (registered materials and built-in materials), which material is to be used for different pipe types such as water supply pipe, stormwater pipe, sewage pipe, etc., relations are to be defined.
    • Among various materials available, which material is to be used for different manholes such as, sewage manhole, stormwater manhole, etc., relations are to be defined.
  • To define/edit the various connections among the registered objects such as pipe-pipe connection, pipe-manhole connection, etc.
  • To configure the drawing setup of various objects in plan view and profile view.
  • To select the cross-section of the trench among various pre-defined and user-defined cross-sections. The selected cross-section will be the active cross-section.
  • To configure the trench cross-section for the position of pipes in the trench, protection layer, standard depth, gradient, rock shelf width, side slopes, distance sideways, etc.
  • To define the trench foundation
Where
The user interface 'Novapoint WS Config' of the function 'Start Configuration' will pop up.
How
The configuration dialogue contains the following menus:
