Use this function to convert an arc (source) into 3D Polyline with a series of straight lines (more break points). The curvature of the converted 3D Polyline with the source can be controlled with the parameter 'Accuracy'.
MOUS_ICO Toolbar: Terrain design: {{}} Straight lines onlyMOUS_ICO Menu:Terrain > Terrain Design > Straight lines only
This function is also available from the module Road Professional
The degree of accuracy determines the number of elemental straight lines, the source object is to be sub-divided.
In most cases, an accuracy of 1.00 is more than sufficient.
Any value from 0.1 to 3.0 or higher can be used. The accuracy and the deviation from the source are mentioned below when a circle with a radius of 10.0m is converted to straight-lines:
Related Topic
