Due to security restrictions implemented in Android 11, it is no longer possible to install or access the storage outside of the Penmap application folder. The application folder must be located inside “Internal storage\Android\data\”. These changes will be mandatory for all Google Play Store apps beginning November 2021.Penmap for Android version 11.4 migrates the folders automatically. If you are upgrading to Penmap for Android 11.5 from an older version you need to perform the migration manually.See the attached document for step-by-step instructions.
