Supported 2D File Formats Browser Windows Mobile BMP DOC DOCX DWG GIF JPEG JPG PDF PNG PPT PPTX RTF TIF TIFF TXT XLS XLSX Notes Trimble Connect for Windows does not have an integrated 2D Viewer, but 2D files can be opened in their native applications from the Trimble Connect for Windows application.
Supported 3D File Formats Browser Windows Mobile DGN (Version 8) DWG 2018 (AutoCAD 2021 and below) DXF IFC (2x3, 4) IFC ZIP IGS, IGES LandXML (Version 1.2) 1 Navisworks (.NWD & .NWC) 2 Revit 3 4 5 SKP (2021 and below) 6 STEP AP203 and AP214 TC ZIP TEKLA TRB Notes Files related to Rhinoceros applications are no longer supported.7 The 3D Viewer does not work with Digital Project and CATIA formats because of changes in licensing agreements.8
The LandXML support is based on the Inframodel subset/extension. Alignments, Pipe Networks, and TIN surfaces are the main primitive types supported. It is now possible to add Navisworks (.NWD & .NWC) model files to the project and view them in 3D using the Connect for Windows application. The Navisworks model viewing is released as a BETA feature. In this stage of the BETA period, the NWD & NWC file formats support plain 3D viewing only. The files cannot be used in other workflows, like for example in creating Views, ToDos or Clash checks. Also, there may be some models that are not rendered correctly or some property data may be incomplete. Revit Add-In required. Versions 2019, 2020 and 2021. It is now possible to add Revit (.RVT) model files to the project and view them in 3D using the Trimble Connect for Windows application. Notes that this feature is not intended to replace the Trimble Connect for Revit Add-In which gives you the most control over choosing which Views get uploaded along with other upload settings. This feature offers a quick, but less controlled, way of getting Revit models into Connect without having to install the Trimble Connect for Revit Add-In. Revit Add-In required. Versions 2019, 2020 and 2021. SketchUp 2021 model format support is only available when the model files are uploaded using the Connect for Windows 1.11 application. If a SketchUp 2021 model file is uploaded using any other application, like the TC for Browser or the TC Sync applications, the file cannot be viewed in 3D in Trimble Connect. This is because the SketchUp 2021 conversion is only available in the local Windows application processing. We’re working to introduce the SketchUp 2021 conversion support also to the cloud processing as soon as possible. This means that the file formats OBJ, FBX, 3DS, STL, 3DM, and SLDASM cannot be viewed using Trimble Connect 3D Viewer. As a workaround, you can export your models from Digital Project and CATIA to IFC format and then import them to Trimble Connect.
Point Cloud File Formats Browser Windows Mobile E57 LAS LAZ Potree URL TDX TZF XYZ Notes Point Cloud URLs must be added through the Trimble Connect for Windows application and then can be viewed on the Browser application.
Geospatial File Formats Browser Windows Mobile GDB1 Geospatial .zip files JXL KML KMZ SHP2 VCA VCE Notes The file size limit when imported in Map Viewer is 40 MB, beyond which the files are supported in the read-only mode. One .zip file should only have one type of geospatial files. For example, a .zip file having SHP and VCE files is not recommended. Shape files may not be processed correctly if the coordinate system information in a .PRJ file cannot be matched to a known coordinate system.
