Novapoint Terrain Library
Symbols Elevation Label
04-12-2021 12:43
Use this function to create labels to objects in the drawing. You can use one of the default labels or create your own.
MOUS_ICO Menu: Terrain > Elevation label > Symbols elevation label…
MOUS_ICO Toolbar: Elevation label > Symbols elevation label…
Working procedure
Start the function and the palette Symbol - Overview opens.
  • Choose a symbol by clicking the preview of it, then press the 'OK' button
  • Specify the insertion point of the symbol elevation label
  • Enter X-scale factor or press 'Enter' to use the default (1)
  • Enter Y-scale factor or press 'Enter' to use the default (1)
  • Specify rotation angle press 'Enter' to use the default (0)
  • Enter the value that is to be written on the Elevation label
Category
In Category, you can choose between Plan, Section, and 3D. For symbols elevation labels, only default labels in Plan are created. Use the drop-down menu to choose a category. Only the category Elevation mark is an option if the user has not created other categories.
Push 'Change category…'-button to change or create a new category. The palette Manage categories opens.
Symbol - Code - Description
Use the drop-down menu to see the preview of different types of symbol elevation labels. If there are more symbols in the category than viewed, press the 'Next page'-button
Description
In Description, the .dwg of the chosen symbol elevation label is written. The user can insert a code or give descriptions to the symbol.
Descriptionfile
The user can open a symbol description file.
