View Entry
Back to Library
Trimble Connect Sync 2.43.7 | Release Notes | Feb 24 2017
Recommend
02-24-2017 23:56
Karthik Rajagopal
New Features
Faster sync with upload & download of files simultaneously
Ability to specify Sync Data Folder
Local file scanning optimization
Cancelled or aborted sync does not roll back already uploaded/downloaded files
Improvements
Correct validation of proxy port field in sync preferences
Allow modification of direction on home page
Bundle up the latest .net version along with the Sync installation screens
Bug Fixes
Sync schedules deleted on network loss
Changing Region of Windows Causes Schedule to not Work
Files not downloading when new revision exists for files in a release
"Parent folder needs permission.." error message changed to "Write Permission required.." after multiple syncs
Project level and Schedule level spinner is spinning in 2 different directions
Files/Folders are not renamed/deleted/moved while syncing after No Access folders are changed to Full Access
Selective sync doesn't retain the check box selection when server folder is changed
Getting Upload completed error message for a conflict file upload to read only folder
Selective Sync is not saving after the server root folder changes
'No records found' message is not shown when the search have no matched records
User not able to select particular folders and files.
Sync.net: "Folder Downloaded" activity is displayed twice in the Sync Activity tab
Old schedules are deleted while changing the config path to new location
Sync.net:Server excluded directories are getting downloaded.
Sync Tool Logging Out User After 8 Hours
Long tool tips are not wrapping
Sync.Net tool does not come up during start up
Upload Only Schedule with Sync Root Set Throws Error On Second Sync.
Data Size param in Sync status pop-up should have units same like web app
'Access Denied' Error Causes Sync Schedule to Stop
When clicking 'Contact Support' Sync App Hangs with Spinner
Exception Message: Object reference not set to an instance of an object
processREQUEST.json contains null value, process.json contains full project data
Getting "System.ComponentModel.Win32Exception" while clicking on Sync Activity after around 2000 lines of entries and hangs
Sync Activity Percentage freezes during sync
Sync Tool Crashed with OverflowException
Contact Support function shown error message and application is crashing
Unable to sync project - Collection Argument is empty
Folder download from Server to Local is not happening through sync
Sync Tool - Not able to Sync getting Error Message from Server, ErrorCode : DUPLICATE_NAME, Message : DUPLICATE_NAME
Project links in Project dashboard page needs to be changed from "app.qa1.gteam.com" to "app.qa.connect.trimble.com"
Error: File/Folder Path Must Be Less Than 260 Characters
Skip is not happening when upload/download fails
Sync Tool Becomes Slow/Unresponsive When Mapped to Network Drive
Working with Selective Sync dialog frequently makes the Sync tool crash
Sync tool crashes when trying to edit the folder path of the selective sync.
Projects are not loaded properly while sync tool is trying to access invalid network path
Project Page Blank After Logging In
Sync tool hangs while accessing sync icon from System tray and all the progressing schedules are stopped if refresh
Spinner keeps on rotating when the server is down
Sync tool ends up with Directory Name Invalid exception
Cannot access commondata network path through sync
Sync tool is crashing when invalid folder path is given
Folder is not Renamed for rename operations after changing from "No Access" to "Full Access" permission
Sync Tool is not working as expected
403 error is seen in UI instead of permission denied message
Activity shows previous schedule actions when Error comes in current schedule
Error messages that needs to be updated
500 error is seen in activity page when project is deleted during UP SYNC
No records found is seen for few seconds while refreshing
500 error is seen in activity page when project is deleted during DOWN SYNC
Trimble connect sync tool Crashed
Preferences is not available when Proxy is set wrong and signout
The renamed folder is getting downloaded as a seperate folder instead of renaming the existing folder in local
Sync.net: Crash while cancelling multiple syncs and signout
#Trimble_Connect_Sync
