System Requirements
02-17-2017 18:47
System Requirements
Updated: 01/01/2025
Trimble Connect for Browser
Starting November 1st 2020, Internet Explorer 11 will no longer be a support browser. We recommend Internet Explorer users to use Microsoft Edge or another supported browser (listed below).
Supported Browsers
Chrome
Edge
Firefox
Safari
Recommended Hardware
Viewing on a Desktop or Laptop
Minimum Recommended
CPU Quad-core 1.6Ghz 8-core 2.60Ghz
Memory 8 GB RAM 16 GB RAM
Storage 10 GB free 32 GB SSD free
Graphics card Integrated GPU
1 GB memory
Discrete GPU (Nvidia, AMD)
4 GB memory
Network 2 Mbps 10 Mbps
Viewing on Mobile or Tablet
For mobile device requirements, see the tab Trimble Connect for Mobile.
Trimble Connect for Windows
Trimble Connect for Windows can be installed on a Windows Desktop, Laptop or Tablet. NOTE: Connect for Windows cannot be installed on devices that have ARM-based processors.
Supported Windows Versions
Trimble Connect for Windows only supports Windows 10 and Windows 11 operating systems.
Windows 10 support ends on October 14th, 2025 (see Microsoft announcement here). All versions of the Trimble Connect for Windows application stop supporting Windows 10 operating system on the same date
Minimum Recommended
Storage 32 GB, 10 GB free 256 GB SSD
Graphics card1 Integrated DirectX 10.1 compatible
2 GB memory
Discrete GPU (Nvidia, AMD)2
4 GB memory
  1. When more than one graphics cards are available in the system, make sure to set the graphics settings of your system so that the higher performance graphics card is used to run the Trimble Connect for Windows application.
  2. High resolution monitors require more GPU. For example, with 4k resolution more GPU is required than with full HD.
Minimum Recommended
Operating System Android 10
iOS 16
Android 13
iOS 16 and above
CPU Quad-core Hexa-core
Memory 4 GB RAM 6 GB RAM
8 GB RAM for complex projects12
Display 750x1334 pixels resolution 1080×1920 pixels resolution
Network 3G or 4G, 2 Mbps Wi-Fi, 10 Mbps
  1. Complex BIM projects could involve one or more of the following (not an exhaustive list):
    • Aggregated size of multiple models : > 2 GB
    • Approximate view size : > 2 GB
    • Views with large number of markups / clip planes / measurements
    • Models with > 2500 object links
    • Models with complex geometries
  2. There are known limitations regarding viewing Navisworks models (NWD & NWC) on mobile devices. Using high-end professional mobile devices with 12 GB RAM are recommended. However, it may not be possible to view all Navisworks models even with the most powerful mobile devices.
14 Downloads
10-27-2023 08:10
buenas sabe estoy intentando configurar por primera vez un GPS TRIMBLE BX 992 y no logro poder acceder a su dirección IP para poder configurarlo que debo hacer o donde puedo conseguir dicha información.
lo intente con WINPAM pero no me da ingreso a la conexión de los cables RS-232.
02-08-2022 05:54
I get this screen when trying to use Trimble Connect for iOS (iOS 15.2.1).  I can log into my Trimble ID just fine using Safari, but trying to use the mobile app stops me right here.  No fields are visible/available to enter my login info.  Any ideas?
10-17-2017 10:06
Hey Richard,
When processing point clouds in Trimble Business Center, recommendations are:
- RAM: 32 GB or more
- Disk: 100 GB or more on solid-state drive
- Graphics:  OpenGL version 3.2 or later; 2 GB graphics card
Notes:
- If you are using a laptop computer with both an integrated (on-board) graphics card and a discrete NVIDIA graphics card enabled via Optimus technology, your computer must allow you to select to disable the integrated graphics card and use only the discreet graphics card when working with point cloud data.
- It is critical that you keep your graphics driver(s) updated if you are working with point cloud data.  Whether your computer has one or multiple graphics cards installed, you must ensure each has been updated with the latest driver provided by the card's manufacturer. The best way to determine if your driver needs to be updated and, if so, perform the update is to visit the card manufacturer's website (If, instead, you decide to update your driver using the Windows Device Manager and the "Search automatically" option, the program may suggest using a Microsoft-approved WHQL version of the driver. However, to ensure you have the latest bug fixes and new features for your graphics card, it is recommended that you use the latest manufacturer version instead.)
Ed Ryan
08-29-2017 15:43
Hi Richard,
You might find this information useful Datasheet - Trimble SX10 Scanning Total Station - English A4
Please contact local dealer for more information via this page. Contact Us | Trimble Geospatial
 Thanks,
Fern Udomrasami
08-22-2017 09:49
What is the spec for the SX10 scanner which is handling millions of points. What size computer is needed.
