Novapoint Noise Library
Terrain Model Codes
04-15-2021 14:00
MOUS_ICO Menu: Noise > Roads and railroads > Terrain model codes…
or
MOUS_ICO Menu: Noise >Roads and railroads > Dialog box
MOUS_ICO Select exactly one road from the list
MOUS_ICO Dialog box: TMOD codes…
or
nco: Select a road (defined in Novapoint Noise)
MOUS_ICO Popup menu: Terrain Model Codes…
The identity of the selected road is shown below the dialog box header. The list in the dialog box displays which feature or group codes are to be switched on/off for the selected road during calculation. See Feature and group codes off/on for a detailed description.
Code type
Feature codes
Show/handle feature codes to be switched off/on during calculation of this road.
Group codes
Show/handle group codes to be switched off/on during calculation of this road.
Defined codes
Delete
Selected feature/group code is deleted from the list.
On
Selected feature/group code in the list is to be switched on during calculation of this road.
Off
Selected feature/group code in the list is to be switched off during calculation of this road.
New code
New code
The new code to be switched off/on during calculation.
New off-code
Add indicated feature/group code from the field New code to the list of codes to be switched off for the selected road during calculation.
New on-code
Add indicated feature/group code from the field New code to the list of codes to be switched on for the selected road during calculation.
Misc.
OK
The dialog box is closed and all changes are saved.
Cancel
The dialog box is closed without any changes taking place.
Help
This page.
