GeoSuite
The program can not start. Error Geosuite.Core.IO.AgrafCls100.dll kan inte hittas
05-03-2023 01:38
The program cannot start. Geosuite.Core.IO.AgrafCls100.dll cannot be found
Userr Error
The program does not start. Cannot find the file Geosuite.Core.IO.AgrafCls100.dll
Problem
There are several possible errors. Error on the shortcut, requirement of restart after installation or missing system variable
Help
Check that the path has a value that ends with “\Binaries” in “Start in” or “Starts in”.
Try restarting the program at least twice.
If the error still persists, add the path: “C:\Program Files (x86)\Vianova\Novapoint\Geosuite\2020\Binaries”
Alternatively: “C:\Program Files (x86)\Trimble\Novapoint\Geosuite\2020\Binaries”
For the PATH system variable
If the system variable PATH already exists, add the path above by positioning yourself at the end of the variable and write ; then the path.
See also: https://community.trimble.com/viewdocument/windows-cant-find-geosuitecoreio-1?CommunityKey=aafa8650-ac02-45f7-9dac-01861822445d&tab=librarydocuments
