View Entry
Tilos
Civil Construction & Infrastructure Solutions
Back to Library
Tilos 11.1 MR3 Release Notes
Recommend
03-25-2022 08:02
David Kosakowski
March 2022
This Tilos release also includes fixes for reported or discovered cases in which:
Import/Export/Data Exchange
When importing data from Microsoft
Project (MSP), additional activities named "#AUTO" were sometimes created in Tilos. In addition, the new activities had links to random successor activities in the file. When a Start Milestone in MSP had a link to a successor, the link was not transferred into Tilos. When the XML file already contained those activities, Tilos did not display them. [TIL-1648]
Activities imported using the Text import profile (.txt) with template settings (all) did not have activity template values assigned as expected. For example, if the assigned activity template has set calculation rules, the created activities had incorrect values set for “Quantity factor” and “Planned work rate”. [TIL-1657]
Activities, Scheduling, Calculations
Only two levels of summaries were being displayed in the "Summaries" tab for a time-distance cell, even when there were more than two levels in the project. All Summaries levels are visible now and can be used. [TIL-1645]
Note:
If your project file is from a previous release, select View > Restore Default Grid Layouts. This will enable the bug fix described above.
1 Files
35 Downloads
Attachment(s)
Tilos 11.1 MR3 Release Notes.pdf
133 KB
1 version
Uploaded - 03-30-2022
Download
Download Document
Please accept the terms of the copyright associated with this attachment before downloading it. Click the link below to read the terms.
Accept
Stuart Jones
03-29-2022 05:28
Its looks like the Summaries still only show to level 2.
Does something special need to be done to see the full list again?
Stuart
