Tilos
TILOS Guide - Getting Started with BIM in TILOS
12-12-2019 10:36
1 Files
100 Downloads
Attachment(s)
pdf file
TILOS Guide - Getting Started with BIM in TILOS.pdf   922 KB   1 version
Uploaded - 11-18-2020
05-01-2020 05:51
Hi Gavin,
Trimble Business Center (TBC) can export data to Trimble Connect, but it will take a bit of research/testing to see if the types of objects are relevant when they make it to TILOS. I will reply here when I find out more. What do you want to exchange?
Of course, you can export mass haul balance information, vertical alignment profiles, and ground profiles from a TBC corridor mass haul analysis using the XML file format (.xml). Then you can import the file into TILOS software to schedule earthmoving. Let me know if you want more information on that workflow. If you are currently a TBC user, search for "TILOS" in the help.
David
04-30-2020 18:03
Hi @David Kosakowski, does this work with Trimble Business Center?
Is there a demo video workflow from Trimble Business Center -> Connect -> Tilos
