Tilos
Tilos System Requirements
03-27-2019 08:41
MARCH 2022
Tilos 11.1+
Hardware
Requirements are the same for a hard disk drive (HDD) and a solid state drive (SSD).
Minimum
  • Dual-core processor
  • 1 GB RAM
  • 2 GB free hard disk space
  • Screen resolution (at 100% font size)
    • QVGA   1280×960 (4:3)
    • WXGA  1280×800 (16:10)
Recommended
  • Quad-core processor, such as Intel Core i5
  • 4 GB RAM
    • Full HD 1920×1080 (16:10)
Operating system
Tilos is tested on the following operating systems (Professional, Enterprise, and Ultimate editions). Tilos will run also on Windows Home Edition, but it is not recommended. Tilos is not supported on Windows Mobile OS.
Client
  • Windows 10 Professional (32-bit/64-bit)
  • Windows 11 Professional (32-bit/64-bit)
Note:  Official testing is done only on Windows 10 Professional (32-bit/64-bit).
File server
For file storage, any resource that is visible in Windows is fine. For example:
  • Windows 2012 Server (64-bit)
  • Windows 2016 Server (64-bit)
  • Windows 2019 Server (64-bit)
  • Most SAN or NAS equipment
For Terminal Server usage requirements, contact the Technical Hotline listed below.
Integrations & Compatibility:
(If the program is backward compatible.)
  • Microsoft Project (Standard and Professional editions) version 2016
  • Oracle Primavera P6 with Primavera-XML-Exchange files versions 7 and 8
  • ASTA Powerproject versions 14 and 15
Note:  See the Support Note - Deploying the Asta Powerproject v15 Fix in the
Tilos Community.
1 Files
70 Downloads
Attachment(s)
pdf file
Tilos System Requirements.pdf   94 KB   1 version
Uploaded - 03-28-2022
