Novapoint Road Library
Trim Alignment
04-19-2021 11:57
Use this function to trim the alignment. It is often required to cut and remove the parts at the start and/or ends of the alignment.
  • Trim command in CAD is not to be used as it destroys the information of the alignment and the database (Quadri Model) is affected.
  • The function makes changes only to the alignment in the drawing
  • The data related to the alignment in the database is unaltered.
MOUS_ICO Toolbar: Draw Horizontal Alignment: Trim Alignment Trim Alignment
MOUS_ICO Menu: Road > Draw Horizontal Alignment > Trim Alignment…
Command prompts for:
Pick baseline:
MOUS_ICO Select the alignment/CAD element (Line/Polyline/Arc) to be trimmed.
The dialog Trim Alignment will pop up.
  • Marks (cross line) referring to the first (green) and last (red) chainage will be displayed on the alignment.
  • The dialog is a floating window, which allows working on other Novapoint/CAD functions without exiting this dialog.
Defining the stretch of alignment to be retained
  • The first and last chainages of the section to be retained can be picked from the drawing using the buttons Pick, adjacent to the fields First chainage and Last chainage.
    • The cross mark moves along the selected line when the button is activated.
    • Follow the command prompt.
  • Alternatively, key in the first and last chainages of the section that is to be retained at the fields First chainage and Last chainage.
  • The section of the selected line within the defined first and last chainage will be retained.
  • The coordinates of the first and last chainage will be displayed at the fields Northing and 'Easting'.
Tip:
  • Make use of Object Snap Modes for accurate selection.
