Trimble Catalyst DA2 Firmware Update Notification
08-15-2022 16:43
Follow this page to receive email notifications of future DA2 firmware releases:
Never miss out on the latest DA2 firmware updates. Follow this page to receive an email notification whenever a new update to the Catalyst DA2 GNSS firmware is available. To do so, click the Follow button in the top right corner of this page. You can unsubscribe at any time by Unfollowing this post. Manage the frequency with which email notifications are received by adjusting your Community Notifications settings located under your User Profile > My Account > Community Notifications.
Current release:
V1.75 (October 2025)
What's new in this update:
  • Updated positioning engine
  • Improved correction age reporting
  • Improved session initialisation performance
  • Improved CMRx ID handling
  • Minor bug fixes and improvements
Release notes history:
A full history of releases (including notes on what has changed) is available in the DA2 Releases topic of the Trimble Geospatial Help Portal, and will be updated shortly.
To install the latest updates:
To check if you have the current firmware version installed on your DA2, and to install any available updates follow the instructions here: How to Update Trimble DA2 GNSS Firmware.
#Catalyst
#DA2
#GNSS
#Firmware
10-11-2023 23:17
This page should also include the updates of Trimble Mobile Manager app and its release notes
10-11-2023 23:14
Is there a button to disable/enable RTX in TMM or in ACCESS2023 subscription?
10-11-2023 23:11
Does the DA-2 antenna uses digital or physical channels for each GNSS signal?   If it uses digital channels what is the maximum number of channel that the DA-2 can use?
Maybe a white paper about the maximum number of channels and each one of the GNSS signals tracked and used is needed for marketing
10-11-2023 23:08
Any chance to integrate Trimble Mobile Manager to ACCESS 2023 subscription app?
It makes sense to have a single app to manage DA-2 updating, GNSS source selection, etc instead of 2 apps
Same for all other Trimble subscription apps such as PenMap, etc
10-11-2023 09:30
Here is where the latest Catalyst FW 1.56 is listed:  https://help.trimblegeospatial.com/Catalyst/DA2-firmware-releases.htm?
10-09-2023 07:20
I agree with Jeff here. When you click on the release notes, it goes to the following page which doesn't show the 1.56 release information: https://help.trimblegeospatial.com/Catalyst/DA2-firmware-releases.htm.
07-20-2023 08:37
It would be really nice if the description of the update was a bit more specific. What did it fix ? What are the improvements ?
02-08-2023 11:53
Thanks Garreth for this update for DA-2    any chance to the registered user be able to get notifications on all subscription expirations (like 30, 15, 5 and 1 day before it expires?)
